Recording Output
Dorsetmike
Recording Output
Post by Dorsetmike » Tue Dec 20, 2011 12:19 am
I tried today to record from Last.fm, I got a very low volume recording. I checked the items quoted above but my Gateway machine has on board Sigma-Tel audio and doesn't offer the "mix" option. I would have to do some fancy connections to use loop back, I have sound in and out to a Technics amp with a Technics turntable for playing vinyl and KEF speakers; any othe suggestions?.
Re: Recording Output
Post by steve » Tue Dec 20, 2011 2:50 pm
Topic split so as to avoid confusion.
Dorsetmike wrote:my Gateway machine has on board Sigma-Tel audio and doesn't offer the "mix" option.
What options does it have?
Which version of Windows?
Is there a "Sigma-Tel" mixer panel?
If you're using Vista or Win 7, have you tried showing disabled and disconnected devices in the Windows Control Panel?
Dorsetmike
Post by Dorsetmike » Wed Dec 21, 2011 12:32 am
The options are line in and front or rear mics.
WinXP SP3
The Sigma Tel mixer has same options line & mics
I've emailed Gateway to check if there are any new drivers, still waiting response!
The PC is a Gateway GT5042b, purchased 2007, dual core pentium, 4Gb ram, 160 & 80 Gb HDDs
Post by steve » Wed Dec 21, 2011 1:21 pm
Dorsetmike wrote:The PC is a Gateway GT5042b, purchased 2007
The latest drivers on the Gateway web site are dated 2010
http://support.gateway.com/product/
