after editing words out of a song, how to shorten the lapse
jnaki
Post by jnaki » Mon Dec 19, 2011 10:43 pm
hello,
i have just completed the first try at editing a song. i have removed the offending words, about 2 sec. worth. how do i shorten the final copy so there is no gap where i took out the words?
thanks
Re: after editing words out of a song, how to shorten the la
Post by kozikowski » Mon Dec 19, 2011 11:20 pm
How did you take out the words?
I do it by drag-selecting the word in the blue waves on the timeline and press DEL. That automatically closes up the hole and shortens the show.
Be sure and make a backup WAV file of your show before you start editing and never record an edited show over old work or original capture files.
