playback after recording (SOLVED)
Re: playback after recording
Post by steve » Tue Dec 20, 2011 1:22 am
It looks like little segments of the sound are being dropped (skipped). This is not an uncommon problem, but unfortunately there are many reasons that this can happen. Basically, some part of the system cannot keep up with the required speed of getting sound from the turntable onto the hard drive. One of the most common causes is if the turntable is connected via a USB hub. Don't connect via a hub, the USB connection should be direct to the computer. After that, there's a list of things to go through: http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers
coltrain
Re: playback after recording (SOLVED)
Post by coltrain » Tue Dec 20, 2011 5:53 am
thanks steve and kos for your help.you fellas are all over this.
Yeah . it was connected via a hub . direct to the computer works fine.
much appreciated.
Cheers Coltrain
Reason: marked solved
