Midi Cables (SOLVED)
pianoverde
Post by pianoverde » Sat Dec 10, 2011 1:29 am
Does Audacity work with midi cables? (I believe that's what they are called)
I have an m-audio Uno - 1-In/1-Out USB Bus-Powered MIDI Interface.
I would like to record straight from this cable if possible because my home can be noisy.
Any input would be appreciated
Re: Midi Cables
Post by steve » Sat Dec 10, 2011 2:21 am
MIDI is not audio. Audacity is an audio recorder and editor, it does not record or edit MIDI.
Re: Midi Cables
Post by Gale Andrews » Sat Dec 10, 2011 2:53 am
steve wrote:MIDI is not audio. Audacity is an audio recorder and editor, it does not record or edit MIDI.
To be 100% accurate, 1.3 Beta can import a MIDI or GRO file, cut-and-paste edit it, then export it, but there is no MIDI playback yet, nor can you convert between MIDI and audio.
http://wiki.audacityteam.org/w/index.ph ... d_Audacity
pianoverde
Re: Midi Cables
Post by pianoverde » Sat Dec 10, 2011 3:18 am
Thank you both, this was helpful.
