resetting Effect
Birdieman
resetting Effect
Post by Birdieman » Fri Dec 09, 2011 3:38 pm
I´ve noticed that changded parameters dont reset automaticly like when you start a new project or restart the program.
Is there anything written about this?
Re: resetting Effect
Post by steve » Fri Dec 09, 2011 3:50 pm
Most of the effects have parameters that reset on restarting Audacity.
"Preferences" are intended to persist so that you don't need to set them to the way that you prefer each time you use Audacity (as is the case with almost all other software).
Which settings in particular do you mean?
Birdieman
Post by Birdieman » Fri Dec 09, 2011 10:48 pm
To me it seemed that when I restarted the program using a microphone and checked the "withhearing" opt. at the mic. icon the sound started to echo in realtime.
I used the echo in my former project.Later on after restarting again it was gone.
I really dont know what happened:),- is it possible to apply effects in realtime and withhearing in this program?
Post by steve » Fri Dec 09, 2011 11:02 pm
When you say "withhearing" do you mean the "Software Playthrough" option in the Transport menu?
Audacity does not do real time effects. If you are getting real time effects they are coming from somewhere else, not Audacity.
Birdieman
Post by Birdieman » Sat Dec 10, 2011 12:05 am
Yeah. software playthrough (I´ve got a Swedish interface). I think I understand the thing now. It was the realtime delay and high mic.vol. that caused the eco. Sorry to bather you. ;)
