LP to mp3 problem
kelloggdental
LP to mp3 problem
Post by kelloggdental » Thu Dec 08, 2011 11:10 pm
I figured out how to convert my LP to mp3 but...(and there is always a but) one side plays just fine but the second side(identical setup) sound like it is in a cave. Anybody else had this problem and figured it out?
Re: LP to mp3 problem
Post by kozikowski » Fri Dec 09, 2011 12:23 am
How did you connect your turntable to the computer? In detail. Part numbers.
kelloggdental
Post by kelloggdental » Sat Dec 10, 2011 6:45 pm
It is a USB connection. The turntable is China made Unknown manufacture Model nbr SPT-106. It is connected to via USB to a Toshiba Satellite (64 bit), Win 7.The only difference in the two recording secessions is changing sides of the LP.
I have used Audacity to download music from the internet and edit with good luck. I used the same computer. The turntable came with poor directions and a cd with a copy of Audacity, nothing else.
Post by steve » Sun Dec 11, 2011 4:50 am
kelloggdental wrote:The turntable came with poor directions and a cd with a copy of Audacity,
Probably an old or obsolete version of Audacity. For Win 7 the correct Audacity version is 1.3.13 which you can download from here: http://audacityteam.org/download/
I don't know if this will help your current problem, but if you have Audacity 1.2.6 then upgrading to 1.3.13 will avoid a number of other problems.
kelloggdental
Post by kelloggdental » Sun Dec 11, 2011 12:00 pm
I am using Audacity 1.3.13 beta. One odd thing just happened. I went to another LP with the usual bad result. So I paused the recording on the control panel and started over without undoing the recording and it go better. So I did it again and it was fine. My settings are Windows, speaker-Real Tech, Microphone arrary, 2 Stereo.
Post by steve » Sun Dec 11, 2011 12:12 pm
Topic moved to the Audacity 1.3.x board.
How big is/are your hard drives and how much free disk space?
Have you defragmented the drive(s) recently?
kelloggdental
Post by kelloggdental » Tue Dec 13, 2011 10:45 pm
I have 379 GB free out of 455 GB. Win 7 defrags itself, not like XP.
Post by steve » Tue Dec 13, 2011 10:59 pm
kelloggdental wrote:My settings are Windows, speaker-Real Tech, Microphone arrary, 2 Stereo.
Could you give a bit more detail about that. Where are those setting? Are those "options" or are they "the selected options"? I'm not sure what you are referring to.
kelloggdental
Post by kelloggdental » Tue Dec 13, 2011 11:28 pm
This is the device tool bar directly under the PLAY, RECORD,STOP buttons on my copy of Audacity 1.3.13
Post by steve » Wed Dec 14, 2011 12:19 am
I thought that might be what you meant, but I now don't understand how you can be recording from the USB input when it appears to not be selected as the recording device.
