When I use the Metadata-editor it displays always first the artist name and project of a previously handled project.
I would prefer an empty field, or better repeat in that case the data that I enter on the first track.
Peter
Metadata editor
petervanderlee
Re: Metadata editor
Audacity handles one set of metadata per project.petervanderlee wrote: When I use the Metadata-editor it displays always first the artist name and project of a previously handled project.
If you just remove the tracks from a project, the metadata will remain because it is still the same project (useful if you are making multiple recordings and want the same metadata for each recording).
If you start a new project (File menu > New, or restart Audacity) then the metadata should be empty.
petervanderlee
Re: Metadata editor
I just started a new project (File - New) and then opened the Metadata editor.
But it showed up again with the project info from the project I did yesterday.
So this seems to be a problem in this version. (I'm using 1.3.13)
Peter
Peter
Re: Metadata editor
It's definitely not doing that on my machine, but I'm currently using Audacity 1.3.14 on Linux (though as far as I'm aware this issue should not be platform dependent).petervanderlee wrote:I just started a new project (File - New) and then opened the Metadata editor.
Which version of Windows are you using? If I can't test it I'll see if I can get someone else to test.
