Hello
I instal audacity 1.3.13 on win 7 32bit , when open a folder witch music ( to load ) audacity don't see nothing although there is set "Files of type: All files *". I try to open some mp3 files many times and audacity don't see it , i don't know whot is wrong ?
Thanks
Audacity don't see mp3 files [SOLVED]
- Quality Assurance
Re: Audacity don't see mp3 files
Do you mean you can select MP3 files in the window, then press "open" and nothing happens? Or the files are silence?bartek158 wrote:Hello
Or do you mean there are no files listed in the window? If there are no files listed in the window, what language are you running Audacity in? You can check in the Interface Preferences.
I mean no files listed in the window. The language was set to "system" (polich) , i change to english and every thing is ok now.
Thank very much.
Thank very much.
- Quality Assurance
Re: Audacity don't see mp3 files [SOLVED]
It was a translator's error and was fixed in the source code soon after 1.3.13 was released. So it will be fixed in the next 1.3.14 Beta which we hope will be released soon.bartek158 wrote:I mean no files listed in the window. The language was set to "system" (polich) , i change to english and every thing is ok now.
If you are not already doing so, you may subscribe here:
http://audacityteam.org/#announce
to receive an e-mail when we release new versions of Audacity.
