I recorded about 58 minutes of audio this morning... and without reading the manual (my VERY bad) I hilited 12:48 minutes at the beginning I wished to delete... but I used "cut" instead of delete. I also did the same thing to a tiny space at the ending. Of course, it then would NOT allow me to save the project. So I just exported it to a mp3 file which seems to play OK.
However, I did save the original folder (that has all the pieces of audio (565mb) in the temp folder) into another partition on my hdd. I have deleted the original original folder of the recording in the temp folder...(the one I messed up and couldn't save) and have copied the copy back into the temp folder.
Now, I would like to put all 565mb in that original folder (three sub folders in there) back into Audacity in one long file as it was originally before I messed it up by cutting instead of deleting on both ends of the file... so I can learn how to do it correctly this time - so I can then save the project... hopefully
Can that be done?? and how??
Thanks for your time,
roxe
