How to recored a set using USB MAYA44 ?
LioGal
Post by LioGal » Thu Nov 24, 2011 1:25 pm
Hello everyone,
Im kinda new here, and to this software so i need a little bit help :)
Well, first of all im using windows 7 and i DJ using Virtual DJ7.
When i DJ, im using my USB MAYA44 (http://www.esi-audio.com/products/maya44usb/ - if you dont know what it is)
and im splitting the sound coming out of my computer to 2 different lines (using the 2 OUT LINES that i have on the MAYA44) on the mixer.
so far so good, now i want to record the MATER line from the mixer back at my computer using my 2 IN LINES (can i use only one?).
SO, i instilled Audacity program, now on the main window i changed the setting on the "mic" to "Line In (AudioDevice on USB)
and hit record but nothing happened, can anyone help me get why?
thanks a lot
Lio
Re: How to recored a set using USB MAYA44 ?
Post by kozikowski » Thu Nov 24, 2011 8:19 pm
Step one: Audacity doesn't support ASIO, so that takes care of four channel sound right there. Windows Drivers only support stereo (2).
You're going to need to fill in come of the holes. Nowhere did you tell us what the mixer was and you only suggest that there is some kind of external mixer. Hardware, right? By who? Model numbers?
I went through all the instruction books and I only got pieces. The Virtual DJ mixes and produces effects and combinations of songs. Nowhere does it tell me what happens after that. Do you make a file for YouTube?
The MAYA44 is just an interface -- that Audacity doesn't support. Audacity might support pieces of it -- like you wanted to use it in stereo.
