Muffling sounds after removing the vocals on an audio
jungminah
Post by jungminah » Sun Nov 20, 2011 6:25 pm
I need help! how can I remove the muffling sounds after I removed the vocals in an mp3/song?
Re: Muffling sounds after removing the vocals on an audio
Post by kozikowski » Mon Nov 21, 2011 12:32 am
The Vocal Remover in Audacity is a simple arithmetic tool that removes everything in the left-right middle of a stereo show. It also usually removes bass and drums and can damage other music as well. The tool in Audacity comes with tools and adjusters that can help if the rest of the performance gets damaged.
Follow the instructions when you launch the tool. You need to be in Audacity 1.3 to get the extra adjusters.
Post by kozikowski » Mon Nov 21, 2011 12:33 am
If you have a highly compressed MP3 song, that may be as good as it gets. MP3 compression has damage of its own and can cause problems with Vocal Removal.
