Looks like track collapse can't be uncollapsed.
After you collapse a track using the arrow at the bottom of the track control area, the track cannot be expanded.
Audacity ® 1.3.13-beta (Unicode)
windows 7
- ww
Track uncollapse doesn't work?
windyweather
Re: Track uncollapse doesn't work?
Topic moved to the Audacity 1.3.x forum.
I don't have Win 7 but I've tested on XP and Linux and can't reproduce the problem.
Could you give a sequence of exact steps, starting with launching Audacity, to reproduce the issue.
windyweather
Very strange
I know that it doesn't always happen. I had about a dozen tracks and only some of them showed this behaviour. After dragging the bottom of the track I was able to open the ones that stuck, but others were stuck with the button. So button is the problem. Dragging the bottom seems to work.
Strange,
ww
Strange,
ww
Does this account for what you are seeing? http://forum.audacityteam.org/viewtopic ... 86#p162710
