HELP! Envelop Tool is LOcKED (SOLVED)
ggodin
Post by ggodin » Sat Nov 19, 2011 9:53 pm
after a recording, if i want to select a part of the segement it will be stuck on envelop tool, thus i cannot edit my stuff!
if i close it, and reopen it, i usually could use the selection tool,
but now it seems stuff everytime so....
yeah
any answers?
Cheers
Re: HELP! Envelop Tool is LOcKED
Post by Gale Andrews » Sun Nov 20, 2011 1:54 am
ggodin wrote:after a recording, if i want to select a part of the segement it will be stuck on envelop tool, thus i cannot edit my stuff!
Probably you have enabled Multi-Tool which is saved in your program preferences. Just press F1 on the keyboard to get back to Selection Tool. Exit Audacity with Selection Tool enabled and it will be enabled when you restart.
ggodin
Re: HELP! Envelop Tool is LOcKED (SOLVED)
Post by ggodin » Mon Jan 16, 2012 5:19 am
Thanks A lot!!
