Please help.
I have used Audacity for years. Recently (this week) I am unable to export SOME of the music I work on. When I go to export I get the following "warning":
You are about so save a MP3 file with the name "blah blah".
Normally these files end in ".mp3", and some programs will not open
files with nonstandard extensions.
Are you sure you want to save the file under this name?
Yes No
When I click "Yes" it appears to export the file. However, it when I go to use that file, it is unrecognizable by ANY player.
The strange thing is that I am able to export some things I edit. While other times I'm NOT able to export.
I would really appreciate any advice anyone could give me please. Thank you in advance.
Export MP3 issues
- Quality Assurance
Re: Export MP3 issues
Don't add a dot (period) in the file name you want to export.
If you need the dot in the file name, type the extension as well. For example if you want to export "dot.com.mp3" type:
in the file name box when you export.
We don't add the extension automatically if the file name contains a dot because otherwise you could never add a "non-standard" extension for a particular file type.
Code: Select all
dot.com.mp3
Do you have Windows set to show you file name extensions? typically, Windows tries to hide all that from you and you never see the .mp3 extension. If you do see it, then the filename is really MyMusic.mp3.mp3 which will confuse some players.
-- Hidden File Extensions
-- Start > My Computer > Tools > Folder Options > View > [ ] Hide Extensions for Known File Types (deselect)
-- Apply (to this folder) or Apply to All Folders
-- OK
Then, yes you should be able to see all the extensions: .mp3 .wav .avi, etc. all normally hidden.
-- OK
Holy Cow!
I feel like such an idiot. Thank you so much for the response. I should have known better. . .
Thanks again!!!
Thanks again!!!
- Quality Assurance
I don't know what happens on Mac, but on Windows and Linux if you add the expected extension in the Audacity file name box, for example:kozikowski wrote:Do you have Windows set to show you file name extensions? typically, Windows tries to hide all that from you and you never see the .mp3 extension. If you do see it, then the filename is really MyMusic.mp3.mp3 which will confuse some players.
Code: Select all
song.mp3
Code: Select all
song.mp3.mp3
Neither of those cases would produce the Audacity error about non-standard extensions.
