Editing a video
TheDarkness73
Editing a video
So I downloaded the ffmpeg, and I edited the audio. How to save the changes to the video, or export it so it is in the video? Or will I have to export it as an audio and then put into the video through other means?
Re: Editing a video
Selection B. Audacity doesn't edit video. Export the show at 48000 WAV, not 44100 WAV. That's much more likely to match the video editing software you use. 48000 is the sample rate for video. 44100 is the rate for music CD.
