I'm using Audacity 1.3 on Windows XP to record audio books. Out of the 10 cassettes, #6 & #10 have not finished recording. Audacity completes the first side of both tapes and switches to the second side. After a period of time, 45 minutes of one tape and 32 minutes of the second, a red line appears on the Audacity screen and the line flickers, but it won't record any further - no flat line, nothing - like it's locked in that moment. The system tells me that there is 117 hours left of recording time so I have plenty of space.
I keep thinking that it may be on the tape since I recording them in order and tapes #7 through #9 recorded fine after #6 blew up on me. Any suggestions?
Audacity quits recording
Re: Audacity quits recording
You posted in the Audacity 1.2 part of the forum. Ill move it to the Audacity 1.3 section.
What are you recording from?
Thanks Steve. I working off a Cassette2USB converter. Nothing fancy but cheap and portable. Judging from the results from the tapes that did convert over, it was easy and sounds fine.
Does the cassette keep playing when Audacity stops?
Yes, the cassette keeps playing but the recording stops.
- Quality Assurance
Check the USB cable for tightness or replace it.
Connect the recorder to a spare USB port, not a hub.
Disconnect other USB devices and close other programs if practical.
Reboot the computer.
Defragment the disk you are writing to.
