Exact amplitude value appear in the status panel?
petrula
Post by petrula » Thu Oct 13, 2011 9:08 pm
As I move the cursor, is there a way to have the exact amplitude value appear in the status panel?
Thanks in advance.
DVDdoug
Forum Crew
Re: Exact amplitude value appear in the status panel?
Post by DVDdoug » Thu Oct 13, 2011 9:54 pm
I'm not sure... But there is plug-in called stats.ny If you select a short section of audio, it will give you the peak & RMS levels for your selection along with a couple of other stats. You can find a link to stats.ny here.
Post by Gale Andrews » Fri Oct 14, 2011 12:31 am
petrula wrote:As I move the cursor, is there a way to have the exact amplitude value appear in the status panel?
No. Are you trying to get the amplitude of a particular sample when zoomed right in, so that moving the cursor up / down does not change the value, but moving left/right does? In that case there is a "sample printer" plug-in which exports a text file containing amplitude values for each sample in the selection:
http://forum.audacityteam.org/viewtopic ... 39&t=34365
Wiki Feature Requests has this request when running with a Spectrogram view of the waveform:
"Crosshair as in Plot Spectrum (2 votes) which enables on-screen measurement of the frequency and dB level" .
Do you want to vote for that?
