Audacity 1.3.12 beta
Windows XP SP3
1 GB Ram
M audio USB Fast Track
When playing back the second track it is out of tune with the first track.
Any Ideas?
recorded tracks are out of tune with first track recorded
Re: recorded tracks are out of tune with first track recorde
What sample rate are you using? (Edit menu > Preferences > Quality)
Sample rate is 44.1K 16 bit
Try setting up the latency correction as described here: http://manual.audacityteam.org/man/Latency_Test
Repeat the test several times.
Are you able to get repeatable results? When set up correctly the latency correction should be accurate to within a couple of milliseconds throughout the recording.
If you are unable to get consistent results, try changing Audacity's default sample rate to 48 kHz, restart Audacity, then re-run the Latency test.
