I can't seem to get Audacity (WIN) to import my LOF list. I've done this before on my mac and loved it.
Can anyone confirm that it IS working on the current beta release?
Confirm LOF import working on 1.3.13?
- Quality Assurance
Re: Confirm LOF import working on 1.3.13?
I tested it recently on 1.3.14 alpha on Windows 7 so I see no reason it should not work in 1.3.13 Beta.pilkro wrote:I can't seem to get Audacity (WIN) to import my LOF list. I've done this before on my mac and loved it.
Please try the tips here:
http://manual.audacityteam.org/man/LOF_Files
If it does not work please give an exact example of a lof file that does not import correctly and state what version of Windows you are using (for example, Windows 7 64-bit).
I'm on Win 7 64bit SP1 6.1.7601
I have the following .LOF file, when I drag it into Audacity, or select "import>Audio|List of files" it just sits there. I recall the version on mac populated each track in a multitrack with the proper files as expected.
Code: Select all
file "G:iTunesMusicThe Left RightsBad Choices Made Easy\02 I'm On Crack.mp3"
file "G:iTunesMusicUnknown ArtistUnknown AlbumWJLB.wav"
file "G:iTunesMusicDas RacistRelax\05 Girl.mp3"
file "G:iTunesMusicSaint EtienneFoxbase Alpha\02 Only Love Can Break Your Heart.mp3"
file "G:iTunesMusicThe Golden PalominosThis Is How It Feels\02 Prison Of The Rhythm.mp3"
file "G:iTunesMusicSensual BedtimeSensual Bedtime\05 Explore Me.mp3"
file "G:iTunesMusicLovageMusic To Make Love To You Old Lady By10 Strangers on a Train.mp3"
file "G:iTunesMusicCalvin HarrisI Created Disco12 Certified.mp3"
file "G:iTunesMusicThe TimeWhat Time Is It_\04 The Walk.mp3"
file "G:iTunesMusicGuitarSunkissed\01 Sunkissed.mp3"
file "G:iTunesMusicWashed OutLife of Leisure\04 Feel It All Around.mp3"
file "G:iTunesMusicPrinceSign 'O' The Times\04 The Ballad Of Dorothy Parker.mp3"
file "G:iTunesMusicJoanna NewsomThe Milk-Eyed Mender\02 Sprout and the Bean.mp3"
file "G:iTunesMusicNenaNena10 Ich Bleib' Im Bett.mp3"
file "G:iTunesMusicThe Ditty BopsThe Ditty Bops\05 Breeze Black Night.mp3"
file "G:iTunesMusicThe Dead MilkmenBig Lizard In My Backyard19 Laundromat Song.mp3"
file "G:iTunesMusicAdam & The AntsAntbox3-20 Wonderful.mp3"
file "G:iTunesMusicR.E.M_B-Sides\06 Arms Of Love.mp3"
file "G:iTunesMusicThe Jazz Mandolin ProjectThe Deep Forbidden Lake11 The Deep Forbidden Lake (Neil You.mp3"
file "G:iTunesMusicHubDaylight\04 The Things That Show.mp3"
file "G:iTunesMusicEmily WellsBeautiful Sleepyhead And The Laughing Ya\05 Big Love Lullaby.mp3"-
- Quality Assurance
Just tried a LOF file in 1.3.13 on Win 7 x64 and it worked fine.pilkro wrote:I recall the version on mac populated each track in a multitrack with the proper files as expected.
There is nothing syntactically wrong with the content of the LOF file as I can see. Have you looked in Help > Show Log to see if there are any errors? Is drive G: available? Does the path "iTunesMusic" on it exist?
Does it make any difference if you reduce the number of files in the list?
No errors in the log file. It thinks it's doing something, but it doesn't give the expected result.Gale Andrews wrote:There is nothing syntactically wrong with the content of the LOF file as I can see. Have you looked in Help > Show Log to see if there are any errors? Is drive G: available? Does the path "iTunesMusic" on it exist?
Paths are correct.
Doesn't matter how many entries are listed as long as there's more than one.
Code: Select all
23:44:12: File name is c:users~~~USER~~~desktopj3 2.lof
23:44:12: Mime type is *
23:44:12: Opening with libsndfile
23:44:12: Opening with liboggvorbis
23:44:12: Opening with libflac
23:44:12: Opening with lof
23:44:12: Opening with libav
23:44:12: Open(c:usershairchalicedesktopj3 2.lof) succeededCode: Select all
23:45:06: File name is c:users~~~USER~~~desktopj3 2 - copy.lof
23:45:06: Mime type is *
23:45:06: Opening with libsndfile
23:45:06: Opening with liboggvorbis
23:45:06: Opening with libflac
23:45:06: Opening with lof
23:45:06: Opening with libav
23:45:06: Error: FFmpeg : av_find_stream_info() failed for file C:Users~~~USER~~~DesktopJ3 2 - Copy.LOF
23:45:06: Error: Importer::Import: Opening failed.
- Quality Assurance
Opening the LOF is just the first stage before Audacity goes through the list of importers to "open" the listed files. For example if the file paths were wrong you would see just the log message that the LOF succeeded but you also would see "can't open" message box errors for each file as well. Do I take it you don't see any message box errors?pilkro wrote:No errors in the log file. It thinks it's doing something, but it doesn't give the expected result.
Paths are correct. Doesn't matter how many entries are listed as long as there's more than one.
Code: Select all
23:44:12: File name is c:users~~~USER~~~desktopj3 2.lof 23:44:12: Mime type is * 23:44:12: Opening with libsndfile 23:44:12: Opening with liboggvorbis 23:44:12: Opening with libflac 23:44:12: Opening with lof 23:44:12: Opening with libav 23:44:12: Open(c:usershairchalicedesktopj3 2.lof) succeeded
So in that case we apparently don't get as far as opening the LOF file to find out what audio file it contains.pilkro wrote: If there's only one line, I do get the error:Code: Select all
23:45:06: File name is c:users~~~USER~~~desktopj3 2 - copy.lof 23:45:06: Mime type is * 23:45:06: Opening with libsndfile 23:45:06: Opening with liboggvorbis 23:45:06: Opening with libflac 23:45:06: Opening with lof 23:45:06: Opening with libav 23:45:06: Error: FFmpeg : av_find_stream_info() failed for file C:Users~~~USER~~~DesktopJ3 2 - Copy.LOF 23:45:06: Error: Importer::Import: Opening failed.
Can you post the contents of that "j3 2 - copy.lof"?
Do any of the files listed in your long LOF file import if you drag those files into Audacity? What about the file in "j3 2 - copy.lof"?
