ffmpeg file version for 1.3 beta(unicode)
Baaul
Post by Baaul » Sun Oct 02, 2011 5:26 am
what should be the ffmpeg file version for 1.3 beta(unicode) ? where can I get it ? Or how can I recognize it ? I tried several avformat-52.dll files but 'ffmpeg library not found' doesn't goes off... using Windows XP Professional 2010.
Re: ffmpeg file version for 1.3 beta(unicode)
Post by steve » Sun Oct 02, 2011 1:59 pm
Topic moved to the Audacity 1.3.x part of the forum.
Use the version from here: http://manual.audacityteam.org/index.ph ... tallffmpeg
This version should work correctly with Audacity 1.3.13.
Check your Audacity version (Help > About Audacity) and if not "Audacity 1.3.13 (Unicode)", upgrade from here: http://audacityteam.org/download/ (just install the new version over the top of the old one.)
