wath is unhandled expection occurred
thanks
salvatore
Re: unhandled expection occurred
It means that there is an error.
For a more precise answer you will have to give a lot more information about the circumstances of this error message.
- Quality Assurance
@Salvatore, Please don't post the same question again after you have already been answered here. I have deleted your other post.
When you reply to a post, please check that "Notify me when a reply is posted" is checked, so that you will be sent an e-mail when someone else replies.
Exception errors in Audacity usually occur due to a memory problem (too little memory, or some other program or process accessing memory reserved for Audacity).
Please look in the Directories Preferences of Audacity and uncheck the "Audio Cache" box if it is already checked. The Audio Cache option writes all your audio edits to memory. See http://manual.audacityteam.org/man/Dire ... nces#cache.
