Hi,
I would like to modify the spectogram of an audio I created that I can make it at a range between 17000 and 21000 hertz. How can I do this?
Thank you for your help.
How to modify the spectrum of an audio?
Re: How to modify the spectrum of an audio?
Since nobody can hear that, many sound cards can't deal with it and you can't put it on a Music CD, what's the job? We need a better idea what you're trying to do.
Yeah... We need to know what you're really trying to accomplish. You can simply generate some high-frequency tones, or the simplest way to increase the frequency/pitch of an existing file is to simply speed-up playback. Or, you might want an Exciter effect which adds high-frequency harmonics.
...a range between 17000 and 21000 hertz.
Of course, you can theoretically go to half the sample rate which is 22,050Hz for a CD. And, if you aren't making a CD, you can use a higher sample rate....you can't put it on a Music CD.
Are you by any chance looking for this: http://forum.audacityteam.org/viewtopic ... 42&t=58548
this is exactly what I'm looking for.steve wrote:Are you by any chance looking for this: http://forum.audacityteam.org/viewtopic ... 42&t=58548
Thank you all.
