Issues with Pasting?
BoilerKisses
Post by BoilerKisses » Mon Sep 19, 2011 10:02 pm
Hello,
I seem to be having issues with pasting. Whenever I paste an audio clip, it speeds up the clip. I've tried using the keyboard shortcuts and the actual copy and paste buttons, and it happens with both.
Has anyone else had this problem or found a solution?
Thank you!
Re: Issues with Pasting?
Post by steve » Mon Sep 19, 2011 10:22 pm
You've posted in the Audacity 1.3 part of the forum. Are you really using Audacity 1.3? (check in the Help menu > About Audacity).
If you're not using Audacity 1.3.13, try upgrading to Audacity 1.3.13. You can get it here: http://audacityteam.org/download/
