e-mail address removed for user protection
Hi. I am using Window's 7, but when I am recording, or playing back, I can't hear anything.
New user - so please help.
Windows 7 - Cannot hear recording
- Quality Assurance
Re: Windows 7 - Cannot hear recording
As you are on Windows 7 please use 1.3.13 Beta:
http://audacity.googlecode.com/files/au ... 1.3.13.exe
Then in Device Toolbar:
http://manual.audacityteam.org/man/Device_Toolbar
set the output device to the device you have your speakers or headphones connected to.
You can right-click the speaker icon by the system clock > Playback Devices, then right-click over the correct playback device to make it default for your system. You can also right-click over the device > Properties then click the "Levels" tab to make sure the levels are turned up and the device isn't muted.
To hear while you are recording, you also have to click Transport > Software Playthrough in Audacity so that it has a checkmark.
There is a Manual built into 1.3.13 at Help > Manual (in web browser).
Thanks I am using Beta version.
Will try again tomorrow
Thanks
Ann
Thanks
Ann
- Quality Assurance
OK. You posted to the 1.2 Windows board though, so I now moved it to 1.3.eastlupus wrote:Thanks I am using Beta version.
