Echo
jokieth
Re: Echo
Post by jokieth » Mon Sep 19, 2011 9:35 am
this was the reply from the seller of the mic
Hi,
Please kindly try to tune the microphone volume at volume manager of windows to solve it.
what does he want me to do?
Re: Echo
Post by steve » Mon Sep 19, 2011 4:23 pm
jokieth wrote:what does he want me to do?
I'm not sure - he's not being very clear.
Was there any software with the microphone?
(I'm wondering what "Built-in Enhanced sound effects processor, with extraordinary expressiveness" means and if there's any way to control (switch off) the "Enhanced sound effects processor".
jokieth
Re: Echo
Post by jokieth » Mon Sep 19, 2011 4:46 pm
unfortunately no the pc doesn't even need to find drivers
Re: Echo
Post by steve » Mon Sep 19, 2011 5:05 pm
You'll have to help me "see" what's happening....
Did we check your Audacity version? It should be 1.3.13 (unicode) - look in the "Help menu > About Audacity" to check.
Any your version of Windows is Vista?
With the microphone connected and your USB headphones disconnected, reboot the computer. When it has fully booted, open Audacity.
Go to: "Edit > Preferences > Devices". What options do you have for the "Recording" and "Playback" devices? Which options are currently selected?
jokieth
Re: Echo
Post by jokieth » Mon Sep 19, 2011 5:15 pm
steve wrote:You'll have to help me "see" what's happening....
Ok i have ver 1.3.13-beta unicode
windows 7 ultimate
the options are: microsoft sound mapper output and microphone high definition audio
Re: Echo
Post by steve » Mon Sep 19, 2011 5:17 pm
Are there any other options available?
What if you change the "Host" setting?
jokieth
Re: Echo
Post by jokieth » Mon Sep 19, 2011 5:20 pm
steve wrote:Are there any other options available?
the only other option there is windows direct sound and that puts the two other options to default. still works and still echo but not as bad ???
Re: Echo
Post by steve » Mon Sep 19, 2011 5:36 pm
Close Audacity, then plug in your USB headphones, wait a few moments for Windows to recognise the headphones, then restart Audacity.
What options do you now have?
jokieth
Re: Echo
Post by jokieth » Mon Sep 19, 2011 6:19 pm
steve wrote:Close Audacity, then plug in your USB headphones, wait a few moments for Windows to recognise the headphones, then restart Audacity.
the same as before with the addition of the headphones for both playback and record (the mic is awful and broken) so i can choose between mics
Re: Echo
Post by steve » Mon Sep 19, 2011 6:55 pm
Your "Headphones" is a "Headset"? (headphones and microphone combined?)
While we are testing this, do you have any "ordinary" headphones? (no microphone, with just a mini-jack plug connector)?
