In Windows 7 my turntable recording levels are way too high, with distortion coming through speakers.
Settings in Sound---microphone, speakers, etc---appear correct. What setting in Windows or
Audacity still could be incorrect?
dB levels past 0, sound distorted
Re: dB levels past 0, sound distorted
It's possible a setting inside the turntable is incorrect. USB sound devices create a digital music stream inside the turntable and that's generally where the volume control is set. It's difficult to reset it later in the system.
You may have gotten a software package with the turntable that can perform adjustments. Consult your instructions.
Thanks for those suggestions, which I've printed out and will follow.
Everything worked fine with the old Windows XP set-up.....................
JS
JS
Problem appears to be resolved---it was the gain level knob, which is now set on minus or zero. I wonder if this
is normal and if it affects the quality of the recording----hard to tell with old vinyl.
Anyway, thanks for your helpful suggestions.
JS
JS
