Hey guys,
I am recording simple narration for my work and it is alot of sound files. Everything is working great except for 7 recordings. For these 7 the entire recording is missing except for about 3-4 seconds in the middle. It is only for these 7 recordings and it is in almost the exact same location (about 20-30 seconds in) in each recording and the recording has saved or remebered only about 3-4 seconds of the recording for the exact same amount of time. Was there a setting that was changed? If so is there a way to change it back to recover what I had recorded? Ideally i would like to recover the recordings but if i have to i can re-record the files.
EDIT: Is it possible that it was the narrator made a mistake?? i wasnt personally doing these recordings it was someone else.
majority of recording missing for 7 recordings only
dstrybsisys
Re: majority of recording missing for 7 recordings only
The number of recordings that I've lost through "user error" I'd be embarrassed to admit.
Audacity Projects are complex things - there can be thousands of little files in the _data folder, tied together by a single XML (.AUP) file. When recording, it is highly recommended to export a back-up WAV file at the earliest opportunity. WAV files are remarkably robust and you can easily burn additional copies to CD if it's a particularly important recording.
This article gives a pretty good overview of the technology involved: http://manual.audacityteam.org/man/Audacity_Projects
dstrybsisys
haha i was afraid of that. Thanks steve! im just glad that it was only 7 recordings and not the entire thing.
- Quality Assurance
Then are you opening Audacity projects (.aup) this other person created, or importing WAV or AIFF files created by the other person? If the latter, click File > Check Dependencies... which should let you see if you can copy in any WAV/AIFF files that the project depends on. If that is the problem, copying the files in will restore the missing audio.dstrybsisys wrote:i wasnt personally doing these recordings it was someone else.
If you are not already using the current 1.3.13 Beta (see Help > About Audacity for your version), please upgrade:
http://audacityteam.org/download/beta_windows#recdown
