Audacity 1.3.13 freezes after recording or importing.
xion1992
Post by xion1992 » Thu Sep 15, 2011 12:41 pm
I love audacity, I started using it early June this year and it worked perfectly for what I was doing. I was recording covers of songs. Most of the time I was multitracking and occasionally I would record a cappella and end up having 10-15 tracks. Recently though, after importing an MP3 it crashed when I tried to do a playback. It hasn't worked since. I can record, but I can't play anything back or it will stop working. I've tried re-installing it, to no avail. I've re-installed my audio playback and recording drivers. I've done essentially all I can think of short of re-installing windows. I'm using a Blue "Snowball" USB microphone. Any help would be appreciated.
Re: Audacity 1.3.13 freezes after recording or importing.
Post by kozikowski » Thu Sep 15, 2011 3:39 pm
Sudden, unexplained computer insanity can be caused by your hard drive filling up. Long recordings, particularly complex, multi-track ones take up a huge amount of drive space.
Start > Computer > right-click your system drive > properties.
xion1992
Post by xion1992 » Thu Sep 15, 2011 3:49 pm
@koz I have a good 50gb free on my hard driv so I don't think that's the problem. Plus, this is happening on single tracks too.
Post by steve » Thu Sep 15, 2011 4:34 pm
Check in "Edit menu > Preferences > Directories" and ensure that "Play and/or Record using RAM" is not selected.
xion1992
Post by xion1992 » Thu Sep 15, 2011 5:06 pm
All the settings were fine. On a whim, I decided to change the location of the temp folder and that seems to have done the trick. We'll find out as time goes by though.
Thanks for the help guys!
Post by steve » Thu Sep 15, 2011 5:41 pm
xion1992 wrote:I decided to change the location of the temp folder
Out of interest, where was it located, and where have you moved it to?
xion1992
Post by xion1992 » Thu Sep 15, 2011 7:29 pm
It was in the audacity section of the appdata folder and I moved it to a folder on my desktop I created called audacity recordings
Post by steve » Fri Sep 16, 2011 12:37 am
We're going a little bit off the original question, but I'm interested in how this occurred.... Do you know the full file addresses of the old and new locations? (for example; D:appdatalocaltemp or whatever).
