Really fast (50x) playback speed possible?
Edgar
Forum Crew
Re: Really fast (50x) playback speed possible?
Post by Edgar » Thu Sep 15, 2011 1:32 am
steve wrote:
ttcheng wrote:Should I think about modifying the transcription toolbar and playback speed code?
That's one of the beauties of open source software. If you know a bit about programming you're free to modify it to suit your own requirements.
Unfortunately I don't think that I'll be able to help with that as I'm not a programmer
I am something of a programmer and have made this modification to my local version of Audacity. You only need to make a tiny change in the code:
srcwidgetsASlider.cpp at or near line #394
Code: Select all
line 364: void LWSlider::SetStyle(int style)
   case SPEED_SLIDER:
      mMinValue = SPEED_MIN;
line 394:      mMaxValue = 8.0f;//efm5 I like more available speed;
      mStepValue = STEP_CONTINUOUS;
      break;
you would want line 394 to read:
Code: Select all
      mMaxValue = 50.0f;
Post by Gale Andrews » Thu Sep 15, 2011 5:48 pm
Edgar wrote:you would want line 394 to read:
Code: Select all
      mMaxValue = 50.0f;
Did anyone test if that worked? Libsamplerate (typically used in Linux distributions) allows 256x resampling, but I don't know about libresample which Windows builds will be using. If the sample rate change allowed by the resampling library is exceeded, Audacity will probably crash.
Edgar
Forum Crew
Post by Edgar » Thu Sep 15, 2011 8:32 pm
Gale Andrews wrote:Did anyone test if that worked?
As Steve notes the max speed possible will depend on various factors. 50.0f works fine on my Win7 SP1 64-bit 3+gHz quad-core machine with 8gB RAM--YMMV <grin>.
ttcheng
Post by ttcheng » Fri Sep 16, 2011 1:38 pm
Thanks so much for your help, especially the code snippet! I'll give that a try.
Tom
