More Effects?
Nisetwist23
More Effects?
Post by Nisetwist23 » Sun Sep 11, 2011 8:32 pm
Under effects I only have 6 effects: Fade In, Fade Out, Leveler, Noise Remover, Normalize, and Truncate Silence. The previous version of Audacity had more effects. Are there more effects located somewhere for version 1.3.13?
Re: More Effects?
Post by Gale Andrews » Sun Sep 11, 2011 10:48 pm
In your previous Beta version of Audacity, or in 1.3.13 without realising, you had enabled the "CleanSpeech" Mode with reduced interface. If you want the full menus, click Edit > Preferences, choose "Interface" on the left, then uncheck "CleanSpeech Mode" and click OK.
CleanSpeech Mode has now been disabled in the source code, so will not be in the next 1.3.14 Beta. Therefore make sure you don't turn it on again by accident because there will be no way to turn it off in 1.3.14 other than in the audacity,cfg settings file.
