NEED HELP WITH EXPORTING FILE
joecool
Post by joecool » Sat Sep 10, 2011 6:46 am
I am really confused. I have exported many songs into iTunes before and they all have worked. However, one of my songs is giving me problems. It will export and I can open it and add it to my itunes library, but when the track plays, there's a loud "exploding" or "popping" sound that comes out of the speakers and the rest of the track is silent. The track works perfectly fine in audacity though, and i can play it and it sounds great. Does anybody know what this means?
Re: NEED HELP WITH EXPORTING FILE
Post by steve » Sat Sep 10, 2011 3:38 pm
What format are you exporting the file as?
What is the "Project Rate" (bottom left corner of the main Audacity window) set at?
