Can't upload exported files to file servers
abuckley23
I'm able to export my audio file in an MP3 format but I can't upload it to any file server sites like media fire or file factory. It uploads but then stalls at file verification. Does anyone have any solutions or suggestions? The file plays fine on various media players.
Re: Can't upload exported files to file servers
What, exactly does the error message say?
There is a file size limit of 200MB for an unpaid user. How big are yours?
MediaFire requires Cookies be enabled on your computer.
abuckley23
There's no error message, it just freezes and I have to restart the browser. The files are only 30-40mb each. It stalls at the 'file verification' part.
- Quality Assurance
Are you actually logged into these sites? Are they 128 kbps 44100 Hz Constant Bit Rate MP3's? Have you added metadata?
Is it a dial up modem? Or USB broadband modem?
Have you tried another browser? Which browser are you using now? Whatever the reason for the failure you should report the freeze to them...
abuckley23
Using a usb wireless modem. Not sure what the meta-whatcha-call-it is? Tried it with mozilla and explorer. Tried mediafire, filefactory and archive.org but results in the same problem.
When you export a file using the "regular" Audacity, it stops and asks you if you want to add information like artist, type of music, dates and comments. If you put information in those panels, it becomes 'metadata'. Data or information over and above what's needed to play the music. The player reads this information and tells the listener what you wrote. You can get into serious trouble if you put characters in the metadata fields that the player doesn't like. Many punctuation marks used to be forbidden.
If you OK the panel without putting any information in those fields, it goes out as blank metadata which is much safer. Audacity 1.3 has a preference you can set where it just stops asking you each time and the metadata is always blank.
Has this ever worked?results in the same problem.
Sadly that's not always the case.kozikowski wrote:Audacity 1.3 has a preference you can set where it just stops asking you each time and the metadata is always blank.
If the project contains imported audio files that already had metadata, then that metadata may be transferred into the Audacity Project.
I wish there were a method of automatically setting Audacity to not include metadata (it messes up the track display in Nero), but unfortunately there isn't.
Metadata can be cleared from the project manually by "File > Metadata Editor", then pressing the "Clear" button.
- Quality Assurance
@abuckley23: I doubt this is an Audacity problem, but you can certainly try "Clear" in Metadata Editor before confirming the export.
Have you asked technical support on the file sharing sites or Mozilla support?
Is your modem close enough to the transmitter?
If you believe it could be an Audacity problem please upload an example MP3 that has this issue to a free
file transfer service such as:
http://www.yousendit.com
http://www.megaupload.com
http://www.sendspace.com
and give us the web address where we can download it.
I bet though that some users would find that in Preferences and turn it on by mistake.steve wrote: I wish there were a method of automatically setting Audacity to not include metadata (it messes up the track display in Nero), but unfortunately there isn't.
I'd be happy if there was just a Preference option to export WAV files without metadata. Including Metadata in Microsoft PCM WAV files is highly unusual. It's quite annoying to have to have the metadata editor pop up just so that I can check that it's empty. If I forget, then to losslessly remove the metadata from a 16 bit WAV file I have to turn off dither, import the file, clear the metadata, export, then turn dither back on again. I don't have any other program that can remove metadata from WAV files (is there one?)Gale Andrews wrote: steve wrote:I wish there were a method of automatically setting Audacity to not include metadata (it messes up the track display in Nero), but unfortunately there isn't.
- Quality Assurance
Yes, that's more sensible. I've argued for such a preference before on -devel and was sitting on a couple of votes that ask for it. I've added your vote (assuming you agree) so Feature Requests now reads:steve wrote:I'd be happy if there was just a Preference option to export WAV files without metadata. Including Metadata in Microsoft PCM WAV files is highly unusual. It's quite annoying to have to have the metadata editor pop up just so that I can check that it's empty. If I forget, then to losslessly remove the metadata from a 16 bit WAV file I have to turn off dither, import the file, clear the metadata, export, then turn dither back on again.Gale Andrews wrote: steve wrote:I wish there were a method of automatically setting Audacity to not include metadata (it messes up the track display in Nero), but unfortunately there isn't.
* Write no metadata (6 votes) - not just disable appearance of metadata editor, not just write empty tags, and should apply to all exports, not just export multiple
** Disable writing metadata only for WAV export (3 votes) - Don't clear Metadata Editor because you may want to export MP3 too
steve wrote: I don't have any other program that can remove metadata from WAV files (is there one?)
There are apps for dealing with metadata in Broadcast WAV (BWF) files but I have not found one yet that helps with metadata in Audacity-exported WAV files (not that I looked hard).
DbPowerAmp (free unless you want MP3 encoding) can remove tags from Audacity-exported WAV's. Should work under WINE on Linux.
