XP, Audacity 1.3.x Generate > Silence is not working
brucegiddens
Post by brucegiddens » Fri Sep 09, 2011 10:20 pm
Windows XP, Audacity 1.3.x(Beta) -- Generate > Silence is gummed up.
The field is filled with impossible numbers (like -48 d, -50 h), and cannot be edited.
DVDdoug
Forum Crew
Re: XP, Audacity 1.3.x Generate > Silence is not working
Post by DVDdoug » Fri Sep 09, 2011 11:06 pm
It's working fine for me.
What format are you exporting to?
How are you looking at the data?
How are you trying to "edit" the file?
Are you sure you are not looking at the file header? What "field"?
Post by steve » Sat Sep 10, 2011 3:00 pm
brucegiddens wrote:Audacity 1.3.x(Beta)
What's the rest of the version number? Is it the Unicode version? (see "Help > About Audacity").
Do you still have this problem after closing and restarting Audacity?
