Removed the bolding - no need to shout ...
Can't get rid of Audacity as a start up program
I'm using version 1.2.6 on an off line PC that's running Win98se. Somewhere in the forum, a person suggested having Audacity come on right after boot up. I can't remember why but I thought I'd try it. Unfortunately it makes Win98 a bit unstable. I tried uninstalling it and then reinstalling it (didn't see it in start up) but it persists in being first in line. Must be some kind of a command hidden somewhere, that I can't find. Any suggestions that would help me get things back to normal would be appreciated. Thanks, Alan
Re: Can't get rid of Audacity as a start up program
I didn't quite follow that. You uninstalled Audacity and it starts on computer boot anyway? How did you uninstall Audacity?
You know you posted an Audacity 1.2 question in the 1.3 forum?
Frankelstner
I suppose you can get rid of it by clicking "Run" in the start menu, typing "msconfig" and unchecking the program in the autostart tab.
You didn't answer the question. Audacity 1.2 had a peculiar installation process.
So what did you do to make Audacity start right after boot up?Soundwave wrote:Somewhere in the forum, a person suggested having Audacity come on right after boot up. I can't remember why but I thought I'd try it.
oops....sorrykozikowski wrote:I didn't quite follow that. You uninstalled Audacity and it starts on computer boot anyway? How did you uninstall Audacity?
I'll try that. Thank you.Frankelstner wrote:I suppose you can get rid of it by clicking "Run" in the start menu, typing "msconfig" and unchecking the program in the autostart tab.
I wish you hadn't asked that. I didn't write down or type a note as to how it was done. Didn't turn the PC on for a couple of weeks. Totally forgot. Oldtimers I guess.steve wrote:So what did you do to make Audacity start right after boot up?Soundwave wrote:Somewhere in the forum, a person suggested having Audacity come on right after boot up. I can't remember why but I thought I'd try it.
It's been a really long time since I've used Win 98.
Have a look in the C:WindowsProgram FilesStartup folder.
Did you put Audacity, or a link to Audacity in there?
