Varying # channels and sample rate
nahidalam
Post by nahidalam » Tue Aug 30, 2011 4:19 pm
Hi,
I am studying the performance impact of audio playback with varying #channels and sample rate of the audio clip.
My goal is to vary 1 property at a time keeping others constant.
-I have a 6 channel 48KH wav file. I want to change the sample rate keeping that 6 channel. But audacity always converts it to 2 channel when I export. can anyone help?
DVDdoug
Forum Crew
Re: Varying # channels and sample rate
Post by DVDdoug » Tue Aug 30, 2011 6:55 pm
I haven't tried this and I don't have a multichannel file handy...
Instead of WAV, select "Custom FFMPEG Export" (I assume you have installed FFMPEG). Then click "Options" and the FFMPEG dialog box pops-up, and you can select WAV, PCM, and other options.
Post by steve » Tue Aug 30, 2011 7:54 pm
To export a multi-channel sound file you need to go to:
"Edit menu > Preferences > Import/Export"
and select the option "Use Custom Mix".
See here for more information: http://manual.audacityteam.org/man/Adva ... ng_Options
nahidalam
Post by nahidalam » Tue Aug 30, 2011 8:14 pm
Thanks steve. That works !!
