I'm a newbie here. Sure could use some help.
Running Windows 7 Ultimate, 64bit, 4 gig, Audacity 1.3.12-beta
I have an hour long cantata that needs to be split into 83 tracks. I marked the tracks and went to the file menu to export but the "Export Multiple" field is grayed out. Can anyone help me? I spent hours splitting that selection!
Thanks.......Tom Theiring
tom <at> theiring [dot} com
Export Multiple problem
Export Multiple problem-Solved
Sorry...I jumped the gun. I found the reason for my problem in the forum.
Problem:... "Export Multiple grayed out"
Answer:... "you must be in Stop and not Pause for the tools to turn black"
Thanks, guys!
Thanks, guys!
Re: Export Multiple problem
It's a bad idea to post your e-mail address on a popular public forum as it is likely to attract a lot of unwanted spam in your mail box. I have partially disguised it to offer some protection against that but you may prefer it removed altogether.
Check that you are actually in Stop mode - It is not possible to Export while in Play or Pause.
Duplicate Topics Merged.
