Problems whilst exporting
Ajinkyash
Post by Ajinkyash » Sun Aug 21, 2011 9:25 am
I am using Audacity 1.3.11 (BETA) version on my windows machine, I edited a song which was of around duration 5:41 minutes, however, when I try to export that file as a WAV file, the file do get exported, showing the same time duration i.e. 5:41 minutes, but when I play this audio, the sounds can be heard for approximately 3:25 minutes and from there onwards it just goes blank till 5:41 minutes....
Can anyone help??? I did reinstalled the audacity software too....still no luck......
Re: Problems whilst exporting
Post by steve » Sun Aug 21, 2011 9:38 am
Audacity 1.3.11 is now obsolete, you should update to Audacity 1.3.13 (you can get it here: http://audacityteam.org/download/ )
Do you still have the Audacity Project?
If so, does it play all the way through?
Do you have enough free hard drive space where you are exporting it to?
Ajinkyash wrote:I did reinstalled the audacity software too
Reinstalling Audacity never cures anything.
Ajinkyash
Post by Ajinkyash » Sun Aug 21, 2011 5:32 pm
Yes Steve, I still have my audacity project and it plays perfectly and fully when using audacity, but when playing through any other audio player it gives me the problem mentioned. And yes I do have ample amount of space in the drive I am using for exporting.. Please help....
Ajinkyash
Post by Ajinkyash » Sun Aug 21, 2011 5:46 pm
Steve,
Please see my response below....
Yes, I still have the project with me...
Yes, it does...the whole 5:41 minutes....
Yes, I have around 13GB of free space......
I have also tries 1.3.13...but still the same problem.... Please help..........
Post by steve » Sun Aug 21, 2011 7:28 pm
Ajinkyash wrote:when playing through any other audio player it gives me the problem mentioned.
That's probably the clue to the problem.
First thing to check is that your "other audio player" will play other (known to be good) audio files all the way through (just to check that we're not looking in the totally wrong area).
Then, in the open Audacity project (Audacity 1.3.13), look near the bottom left corner for the "Project Rate" and ensure that it is set at 44100 Hz. If it isn't then change it.
Then check that no tracks are muted in the Audacity Project and "File menu > Export" (NOT "Export Selection") and Export the project as a WAV file (Microsoft PCM 16 bit).
When you export, ensure that it is to a place on your hard drive that you have permission to write to (for example "My Documents") and save the file with a new, unique file name.
Use only letters and number in the file name - no punctuation marks or other special characters.
The WAV file should play correctly (fingers crossed).
Ajinkyash
Post by Ajinkyash » Mon Aug 22, 2011 10:58 am
Thanks Steve, tried the solutions you provided....but unfortunately still no luck.....Can changing the EDIT>preferences settings be of any help???
Post by steve » Mon Aug 22, 2011 12:53 pm
Ajinkyash wrote:Can changing the EDIT>preferences settings be of any help???
Possibly, but do you know what to change and what to change it to?
steve wrote:Then, in the open Audacity project (Audacity 1.3.13), look near the bottom left corner for the "Project Rate" and ensure that it is set at 44100 Hz. If it isn't then change it.
What happened with this test?
What was / is it set to?
steve wrote: and Export the project as a WAV file (Microsoft PCM 16 bit).
What exactly happened when you did this?
