cant export to mp3, im told lame_enc.dll needs updating
chessman
Post by chessman » Sat Aug 20, 2011 11:39 am
Oh but my lame_enc.dll is the latest, infact ive even tried the unstable beta, so why wont Audacity let me use it? I try to export to mp3, I get told to locate lame_enc.dll. So I select lame_enc.dll from a folder and it tells me the version is not compatible, please download latest. So I do that and it errors out. This is on 1.3.13-beta (Unicode). The previous version 1.2.6 works fine with lame_enc.dll. I dont want to go back to 1.2.6 just to use lame. So for now im exporting to wav's then running a batch script to execute lame.exe and encode the wavs, but would be nice to have the lame mp3 bug fixed
Re: cant export to mp3, im told lame_enc.dll needs updating
Post by Gale Andrews » Sat Aug 20, 2011 12:39 pm
chessman wrote:Oh but my lame_enc.dll is the latest, infact ive even tried the unstable beta, so why wont Audacity let me use it? I try to export to mp3, I get told to locate lame_enc.dll. So I select lame_enc.dll from a folder and it tells me the version is not compatible, please download latest. So I do that and it errors out. This is on 1.3.13-beta (Unicode). The previous version 1.2.6 works fine with lame_enc.dll. I dont want to go back to 1.2.6 just to use lame. So for now im exporting to wav's then running a batch script to execute lame.exe and encode the wavs, but would be nice to have the lame mp3 bug fixed
You can't use arbitrary copies of lame_enc.dll with 1.3.Beta - the .dll has to be obtained from us. This is done so as to improve the metadata and file information support in exported MP3s.
Please download LAME by following the instructions here.
If the dll from those instructions is not recognised by Audacity, try these instead:
However if you install LAME as directed on http://manual.audacityteam.org/man/FAQ: ... g-Ins#lame, then even if File > Export > MP3 does not recognise lame_enc.dll, you can use the included lame.exe to export MP3s from Audacity using Audacity's command line exporter.
chessman
Post by chessman » Sat Aug 20, 2011 2:35 pm
got it sorted out now, thanks.
scottna
Post by scottna » Fri Oct 28, 2011 12:52 pm
This worked for me - running Audacity 1.3.13-beta as a PortableApp from a USB stick
•lame_enc.dll 3.98.4 from:
download/file.php?id=2998
