Exporting blank files
Exe
Post by Exe » Sat Aug 20, 2011 2:30 am
So out of the blue it started exporting wav files blank. I checked ever setting, restarted the computer, even re installed the program, its still not working. I can't find any help online. If any one had any suggestions please help. Thanks
Re: Exporting blank files
Post by steve » Sat Aug 20, 2011 12:45 pm
Which exact version of Audacity are you using? (look in "Help > About Audacity")
Do the Audacity Projects play correctly before you Export the files?
If you Import one of the "blank" files into Audacity, does it show a waveform? Does it just show a flat line? Does it play?
What format are you exporting as?
What is the "Project Rate" set to (near the bottom left corner of the main Audacity screen)?
Post by Gale Andrews » Sat Aug 20, 2011 12:49 pm
Exe wrote:So out of the blue it started exporting wav files blank. I checked ever setting, restarted the computer, even re installed the program, its still not working. I can't find any help online. If any one had any suggestions please help. Thanks
Also:
  • If you are using Export Multiple, make sure tracks are not muted and that there is audio where your labels are.
  • If you are using normal Export, make sure if you have multiple tracks that you are not using Export Selection. Make sure you have not turned the -....+ gain slider down on the track(s).
If that does not help, please use "Upload attachment" underneath the Preview/Submit message buttons to upload an image of your track layout (and answer Steve's remaining questions so that we know) .
Exe
Post by Exe » Sat Aug 20, 2011 8:07 pm
I am using 1.3. Project rate is 4100. I think it must be some kind of bu in the system because it was always working fine. But I tried to re install it and its still doing it. It only does it with aup files tho. If I import an mp3 it exports just fine, but aup files stopped exporting
Post by steve » Sun Aug 21, 2011 5:13 am
Exe wrote: but aup files stopped exporting
AUP files are not audio files. http://manual.audacityteam.org/man/Audacity_Projects
Post by Gale Andrews » Sun Aug 21, 2011 12:50 pm
Exe wrote:I am using 1.3.
The current Beta is 1.3.13. You can check which exact version of 1.3 you have at Help > About Audacity. If you are using a Beta before 1.3.10 it has a bug that playing, rendering or exporting multiple tracks could lead to desynchronized playback or loss of audio data.
Exe wrote: Project rate is 4100.
I doubt that. If it was, the exported audio would sound very dull because it would not have any higher frequencies than 2050 Hz. The exported file would also be quieter if the track you were exporting from was at standard 44100 Hz. Is 44100 Hz what you mean?
Exe wrote:aup files stopped exporting
To open an .aup Audacity project file you have to use FIle > Open, otherwise you will not produce any audio on the screen.
If you have a problem with a particular project that actually contains a waveform with peaks and troughs like this:
http://manual.audacityteam.org/m/images ... xample.PNG
please give us a screen shot so we can see what the problem is. But make sure you are using 1.3.13 first.
If you mean .au files from the Audacity _data folder, leave those alone, and open the .aup file instead.
