Error while opening sound device. Please check the input device settings and the project rate sample.
I was recording w/this for a long time, and out of no where it says that! please help! I love audacity
PLEASE HELP: Out of no where, when pressing record, it says
Re: PLEASE HELP: Out of no where, when pressing record, it s
What's your setup?
XP / Vista?
Desktop / Laptop?
Sound card?
USB audio device?
Audacity 1.3.5?
Too much information is better than not enough.
If you are using a USB audio device, make sure that it is connected, switched on and recognised by Windows before you open Audacity.
If you are recording through your sound card, do not connect any USB audio devices to your computer.
Also, check the Audacity settings in "Edit > Preferences > Audio I/O" and "Edit > Preferences > Quality"
XP / Vista?
Desktop / Laptop?
Sound card?
USB audio device?
Audacity 1.3.5?
I use XP, a desktop, and a USB audio device called Logitech AK5370. It supports the project rate that I use, and it still doesn't work. I use Audacity 1.3 Beta (Unicode)stevethefiddle wrote:What's your setup?
XP / Vista?
Desktop / Laptop?
Sound card?
USB audio device?
Audacity 1.3.5?
It started not working out of no where!
Make sure that the sound card is connected, switched on and recognised by Windows, then open Audacity.
Look in "Edit > Preferences > Audio I/O" and "Edit > Preferences > Quality" - What is selected for the Recording device? What is the default sample rate and bit depth set at? How many recording channels are set?
If necessary, correct any of the above settings, then close and restart Audacity so that the changes will take effect.
