I am recording from a personal recording device. I am recording via "line in". I am using pass thru during recording to monitor the recording. I am recording in "mono". When I do a test playback, to check volume, all sounds great. The wave form is fine. When I begin recording, I get a time delay between the speakers, an echo. The wave form still looks good. If I playback what is recorded, it sounds fine. Problem appears to be with playthru......
Any suggestions or help??
Echo on recording
Re: Echo on recording
I solved the problem....
On PC, Make sure "Play Through" is not checked,,,,,
Or possibly due to the sound card...
anyway echo gone when playthrough disabled
