Problems with sound and windows XP
georgeV
Post by georgeV » Mon Aug 15, 2011 9:12 pm
I am on Windows XP Service Pack 3 on a Compaq Presario pc and have a Zennox USB Turntable and I want to record LPs onto my computer. The software Audacity 1.2.6 came with the turntable and I have downloaded the 1.3 Beta version from the Audacity website. I have searched through many forums/websites and adjusted sound settings both on preferences on Audacity and on my pc etc but I either don't get any sound playing through my computer when playing a record on the turnable or I get a loud buzzing noise, therefore it's either not recording any sound or just recording the buzzing noise. Can you advise me on the settings I should have to make it work or will it not work with the equipment/pc I have? Thanks.
bgravato
Re: Problems with sound and windows XP
Post by bgravato » Tue Aug 16, 2011 12:05 am
Is there any settings with which you can record successfully even if you can't hear it during recording?
You should select the USB device as the recording device in Preferences -> Devices -> Recording Device
You should connect the turntable to the usb port and turn it on before running audacity, so that it's properly detected and available from the device list.
To listen to it while recording you might need to enable "Software Playthrough" from the Transport menu.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
waxcylinder
Post by waxcylinder » Tue Aug 16, 2011 9:20 am
Have a look at this set of tutorials in the 1.3 manual: http://manual.audacityteam.org/man/Tuto ... iscs_to_CD
Especially this one: http://manual.audacityteam.org/man/Reco ... turntables
