Can't burn Audacity recording in iTunes to CD
carolynbbennett
Post by carolynbbennett » Sat Aug 13, 2011 9:00 pm
I have successfully added a cassette tape recording of my parents talking from 4 decades ago into my iTunes library and can play the recording on my Dell laptop (Windows Vista) in iTunes. However, when I burn the recording to a CD-R as an Audio CD (as opposed to a Data CD), and then attempt to play the newly burned CD on my CD player, nothing is heard and then the CD stops and the player shows an "err" message. I also tried converting my recording in iTunes to ACC format and then burning it, but the same thing happens. :shock:
Is it a given that: :idea: IF this audacity recording will play on my laptop in iTunes, THEN it can be successfully burned to CD? or do I need to go back to the drawing board :?:
Thank you!
Re: Can't burn Audacity recording in iTunes to CD
Post by kozikowski » Sun Aug 14, 2011 12:40 am
We just talked somebody else through this same problem.
http://forum.audacityteam.org/viewtopic ... 25#p152822
This is the short version...
Export the music from Audacity in WAV (default) format.
http://forum.audacityteam.org/viewtopic ... 25#p152880
