Exported MP3 or WAV completely silent
sonya
Post by sonya » Wed Aug 10, 2011 4:17 pm
I've just downloaded Audacity 1.3 Beta on Windows 7 and have recorded my first test tracks on a Blue Yeti USB mic. The playback in Audacity is working just fine.
When I export my track to MP3 or WAV, the resulting file is completely silent. I tried importing it back into Audacity, and it played back fine. Based on the response to another question, I went into Control Panel and set my speakers to my computer speakers rather than my microphone. The export options are just on default settings, which are Constant Bit Rate Mode, Quality 128 kbps, Joint Stereo. I've also tried setting it to Stereo instead of Joint. The audio track is set to Mono (it's just a voiceover), 44100 Hz, 32-bit float (I've also tried 16-bit PCM). There is no clipping in the track. Software Playthrough is turned off, and mute is turned off.
Any advice? Thanks!
Re: Exported MP3 or WAV completely silent
Post by Gale Andrews » Wed Aug 10, 2011 11:29 pm
The other response you read is correct. You need to go to the "Playback" tab of "Sound" in the Windows Control Panel, and make sure the computer speakers are listed as "Default Device". If not, right-click over the speakers > "Set as Default Device".
Also you will probably need to restart whatever application was playing the exported file in order for it to recognise the change in default playback device.
sonya
Post by sonya » Thu Aug 11, 2011 12:14 am
As you described, that worked perfectly. I thought I had tried everything, but... guess not. Once I got that sorted, everything else I needed to do worked out!
Thanks for your quick reply!
Sonya
