Export WAV in chain changes bit rate
Re: Export WAV in chain changes bit rate
Permanent link to this post Posted by Gale Andrews » Sat Aug 20, 2011 2:54 pm
stevetel007 wrote:I have the same problem. I have to export files all the time as WAV 8 bit for phone systems menus and music on hold. May I also get the fix?
I've sent you a private message with a link to a zip file containing an unofficial 1.3.14 alpha version of Audacity. This adds support for FFmpeg export and "Other Uncompressed Files" export to Chains. There are a couple of limitations as mentioned in my message.
Permanent link to this post Posted by hankeje » Sat Aug 20, 2011 5:03 pm
I need this capability for phone systems as well and would like this fix...
hankeje
Permanent link to this post Posted by Gale Andrews » Sun Aug 21, 2011 12:00 am
hankeje wrote:I need this capability for phone systems as well and would like this fix...
Do you explicitly want it for a Chain? You can already export 8-bit WAV without a Chain by choosing "Other uncompressed files" when you export, then click "Options".
Permanent link to this post Posted by hankeje » Sun Aug 21, 2011 2:29 am
Yes, for use in a chain where I normalize and truncate silence...then need to convert to small rate such as GSM6.10 or equivelant.
hankeje
Permanent link to this post Posted by Gale Andrews » Sun Aug 21, 2011 1:13 pm
hankeje wrote:Yes, for use in a chain where I normalize and truncate silence...then need to convert to small rate such as GSM6.10 or equivelant.
OK I've sent you a private message with a link to the zip file containing an unofficial 1.3.14 alpha version of Audacity. This adds support for FFmpeg export and "Other Uncompressed Files" export to Chains, and it also adds an explicit "ExportGSM" chain command for the "GSM 6.10 WAV (mobile)" export item.
Permanent link to this post Posted by autordesk » Thu Apr 12, 2012 8:15 pm
Hi, I would love a copy of this alpha release also.
Thank you!
autordesk
Permanent link to this post Posted by steve » Fri Apr 13, 2012 2:41 am
autordesk wrote:Hi, I would love a copy of this alpha release also.
Thank you!
The alpha release is no longer relevant. You are replying to a post that is over 6 months old. That alpha version has been superseded by Audacity 2.0 which is available here: http://audacityteam.org/download/
Permanent link to this post Posted by autordesk » Fri Apr 13, 2012 9:05 pm
Sorry - this was the only thread that discussed my issue. Should I start a new one?
Unless I missed something, the beta version you provided a link to does not have the ability to export an uncompressed file in a Chain. This is what I am looking for so I can batch edit a whole bunch of wavs for our phone system.
autordesk
Permanent link to this post Posted by steve » Fri Apr 13, 2012 10:56 pm
Audacity 2.0 supports exporting 16 bit WAV files in Chains.
Permanent link to this post Posted by autordesk » Fri Apr 13, 2012 11:00 pm
Thanks for your response, Steve.
I need to export 8 bit mono ulaw wav files en masse.
I can do this one by one using Export, but I would really rather use the Chain functionality, since I have over 200 files to process.
autordesk
PreviousNext
Return to Windows
Who is online
Users browsing this forum: No registered users and 8 guests
