White Noise Being Produced
jasonvtaz
Post by jasonvtaz » Thu Aug 04, 2011 7:38 pm
I'm running audacity 1.3.13 on a new Asus laptop. On my old computer, with Audacity 1.2 I could capture the audio my computer was produced by selected stereo mix and pressing the record button, which was easy enough. On my new computer, audacity is recording a white noise/static that I can't hear out of my speakers as it records, but can be heard when I play it back. Anyone know a way I can get rid of this noise?
Re: White Noise Being Produced
Post by kozikowski » Fri Aug 05, 2011 12:21 am
Newer computers tend not to have Stereo Mix at all. Chances are you're really recording one of your unused or unconnected inputs which will just give you electronic noise.
Audacity is a complete slave to what the computer is doing. What did you set your Windows Control Panel to?
Post by steve » Fri Aug 05, 2011 12:22 am
So you're saying that you have selected "Stereo Mix" on the new computer and there's a lot of noise mixed in with the recording?
jasonvtaz
Post by jasonvtaz » Fri Aug 05, 2011 6:35 pm
kozikowski wrote:Newer computers tend not to have Stereo Mix at all. Chances are you're really recording one of your unused or unconnected inputs which will just give you electronic noise.
I have stereo mix turned on, I'm not sure what you mean by setting control panel to. I found that when I plug in headphones I can hear the static coming through the headphones.
jasonvtaz
Post by jasonvtaz » Fri Aug 05, 2011 7:10 pm
steve wrote:So you're saying that you have selected "Stereo Mix" on the new computer and there's a lot of noise mixed in with the recording?
Yes, the noise is being produced even if I'm not recording anything. I can't hear it just sitting in front of my computer, but I plug in headphones or record something in audacity it can be heard. Now I'm having other speaker issues, but I'm not sure they're related.
Post by steve » Fri Aug 05, 2011 7:57 pm
Mute the microphone and line input.
