I am using a Vista computer running through a Lexicon interface (use also cubase) and I am getting a moderate amount of sound distortion with Audacity beta 1.3..
I love this program and use it to modify mp3 background track to use in my professional show. When I start 1.3 it does give me a message that says it cannot load lexicon plug in? I do get clean sound using other programs.
Can you give me some help as what I can do to correct this?
Thanks...Bill
moderate distorted sound with beta 1.3
Re: moderate distorted sound with beta 1.3
What are you doing with Audacity? Audacity won't add any distortion to a file unless you "do something"... And of course, it depends on what you are doing...I am using a Vista computer running through a Lexicon interface (use also cubase) and I am getting a moderate amount of sound distortion with Audacity beta 1.3..
Are you recording with Audacity, or are you modifying a file? If you are editing a file, what are you doing? Anything that boosts volume can cause clipping (distortion). And of course MP3 is lossy, and when you re-save, you go through a 2nd loss compression step. A high quality setting (high bitrate) will minimize quality loss.
I don't know... Is it a VST plug-in? It's possible the the plug-in isn't compatible with Audacity. (Audacity should be compatible with the Lexicon hardware as long as the lexicon has a regular Windows driver.)When I start 1.3 it does give me a message that says it cannot load lexicon plug in?
Thanks Doug,
I am taking MP3 files off (karaoke) backing files (songs) and modifying them. I may change the key - pitch and tempo. I try to normalize them so the volume level is the same one to another and sometimes I will boost the bass. Then I save them as MP3 files.
I am a professional singer and I use these for shows and nightclubs.
Yes, I get a small amount of distortion in my playback using the monitor speakers with my computer. I don't get these distortion if I playback the same files in iTunes or Windows Media and when I burn the file to a CD the distortion is not there??? How can I tell if my Lexicon interface is not set correctly?
I would like to have the best quality I can for play back on a job so could you suggest another way of saving these files. Plus where or how do I set these up with Audacity. If I change format, what program can I play these back with??
By the way, Audacity 1.3 has the very best pitch changer I have ever used..
Thanks for your help...
The distortion in Audacity might be annoying, but it isn't terrible since I assume you're not using Audacity for your live performance.
Well... I guess whatever you are using is OK, since it sounds good with iTunes or Windows Media Player.I would like to have the best quality I can for play back on a job so could you suggest another way of saving these files.
First, you need to make sure the file is not clipping* (View -> Show Clipping). If you are clipping after boosting the bass, etc., Use Amplify and set the new target-peak level at something like -0.1dB. (It's important to do this before you save, because Audacity can go over 0dB with it's floating-point processing, but many file-formats cannot, and the peaks can be clipped when you save.) If it doesn't sound loud enough after that, the trick is to use some dynamic compression.** (And you might need to re-normalize the peaks to -0.1dB again after compression.)
WAV is uncompressed, so there is no quality loss (assuming the same sample rate & bit-depth as the original). And, just about anything will play WAV. The downside to WAV (besides file size) is that tagging (title, artist, etc) is not standardized. FLAC and ALAC are lossless compression, so they sound identical to the original WAV. iTunes supports ALAC, and with an add-on CODEC, Media Player supports FLAC (i think).
MP3 and AAC will play on almost anything too. And at high bitrates, they will sound identical to the original with most music. The highest quality settings for MP3 are 320kbps CBR (constant bitrate) or LAME 'V0' VBR (variable bitrate). (I'm ot completely up to speed on AAC settings.)
File -> Export. Then you can select the file type, and set the bitrate or other details under Options. (If you want to save-as MP3, you need to install the optional LAME encoder.)Plus where or how do I set these up with Audacity?
Since you can create almost any format you want, I'd start with the application you want to use, and then choose a format that works.If I change format, what program can I play these back with?
i can't help; you with that... I don't have one. What are you using it for? As a playback "soundcard"? I thought most of the Lexicon devices are used for recording, but you didn't say anything about recording....How can I tell if my Lexicon interface is not set correctly?
[/quote]Since computers are unreliable, I get nervous when people use them for live performance.I am a professional singer and I use these for shows and nightclubs.
* The original file might show some clipping, and there's not much you can do about the flat-topped waves (except maybe with the Clip Fix effect). The important thing is that you don't add any more clipping.
** Dynamic compression is a non-linear process and you can boost the quiet & moderate parts without boosting/clipping the peaks. This has no relationship to file compression like MP3. i.e. You can boost the overall/average volume without clipping. Most modern CDs are highly dynamically-compressed. Most older recordings have more "dynamics", but are not as "constantly loud".
