Not able to record
Jim Bob
Not able to record
Post by Jim Bob » Thu Jul 28, 2011 4:04 pm
I operate Wind. 2007. It has a built in mic. After downloading Audacity I assumed I would be able to hit the record button,start talking then hit stop then hit play and I would be hearing my recording.
This is not happening, where am I going wrong? thanx.
Re: Not able to record
Post by kozikowski » Thu Jul 28, 2011 4:17 pm
Audacity can only do what the Windows machine tells it to. You need to set your Windows Control Panels to record from your microphone first.
Then set Audacity Preferences to record from the same thing. Then press record. Audacity will record from several different sources inside your computer and you need to tell Windows which one you want. Sometimes Audacity can do the switching by itself, but it's much more reliable to tell Windows.
Jim Bob
Post by Jim Bob » Thu Jul 28, 2011 10:08 pm
Do I need to buy an external mic. to record with Audacity? It seems from the area you sent me this is the case. Thx. jim
Post by Gale Andrews » Fri Jul 29, 2011 12:49 am
There is no such operating system as "Windows 2007". Assuming you mean Vista or 7, exit Audacity then go here;
http://wiki.audacityteam.org/index.php? ... es#vistacp
for instructions to get to "Sound" in the Windows Control Panel. Then right-click in the "Recording" tab to show the disabled and disconnected devices, then right-click over the internal mic and choose "Enable". Then start Audacity and choose the internal mic as recording device in the Devices Preferences.
