How to make funny/cartoon voice?
sonnik
Post by sonnik » Tue Jul 26, 2011 10:02 pm
Hi and hello,
I'm using Audycity for a while now for some things but I'm wondering if there is some filter to make my own voice sounds like something from cartoons?
I would be very happy if someone could help me.
Thank you,
sonnik
Re: How to make funny/cartoon voice?
Post by steve » Tue Jul 26, 2011 10:18 pm
Try the "Change Speed" effect.
Record yourself talking very slowly, then use "Effect menu > Change Speed" to speed it up.
sonnik
Post by sonnik » Tue Jul 26, 2011 10:28 pm
That is good idea, but what if I want to make the length of recording same or very similar like the original?
Because I want to use my 'modified' voice for one already made video and if I speed up I missing some seconds of recording at the end :-)
Thanks
Post by kozikowski » Tue Jul 26, 2011 10:41 pm
That's why you have to do it in two steps. If 20% faster is appropriate pitch, then you need to speak slowly 20% longer to have everything come out right.
There is Change Pitch, but nobody likes the way that sounds.
Post by steve » Tue Jul 26, 2011 10:41 pm
Try the "Sliding Time Scale/Pitch Shift" effect.
Set the Initial and final "Tempo" settings to zero and adjust the "Pitch" settings to get the cartoon voice.
