choosing how i want to rcord
curiousgeorge
just downloaded this great product but how do choose how to record i.e microphone, line in etc
friday jones
Re: choosing how i want to rcord
Assuming Windows XP, double-click on the speaker icon in your tray at the right of the task bar. Under Options, select properties, and tick Recording, then make sure that all of the options on the list box are ticked, and then click OK. Whichever device in that list has the Select box ticked is the device Audacity will record from.
curiousgeorge
sorry its windows vista
For Vista you should use Audacity 1.3.13 http://audacityteam.org/download/
curiousgeorge
Re: choosing how i want to record
im already using this version
friday jones
For Vista, right-click the speaker icon in the tray on your taskbar, choose Recording Devices, highlight a device from the list, and then click Set Default. The device has to be enabled, plugged in, and ready to use or the Set Default button will be grayed out.
curiousgeorge
i only have microphone listed
curiousgeorge
now when i try to record i get this message
error while opening sound device check input device settings WHAT HAVE I DONE
Please check which part of the forum you are posting to. This was posted in the Audacity 1.2.x section. Now moved to the Audacity 1.3.x section.
See here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panelcuriousgeorge wrote:i only have microphone listed
curiousgeorge
thanks alot steve i will more careful where i post in future
